my computer (CPU) according to Core Temp has a min of 9 C with my 2 new fans i installed.
a max of 24 C.
can this low of temp cause a computer to lagg? if so should i remove one of the fans? i got 2 intake 1 out.
before both fans my computer after like 2 mins ran at like 35-40 C.
or could it be a lack of PSU?
Spec:
CPU: fx4100 (3.6ghz)
graphics: AMD Radeon 6770
Ram : 8gb
1TB HDD
3 fans
600W PSU
Disc Drive
i am pointing to either temp or the PSU bc 1 its a new LOW for my computer in temp and adding the fans require more power which could be over it.
also i started to smell a burning motor smell it might of been the drill i was using (i was pushing its limits) but could a computer cause that
smell?
a max of 24 C.
Spec:
Ram : 8gb
1TB HDD
3 fans
600W PSU
Disc Drive
smell?
