Hello. It's my first post here, please be gentle.
I recently built the following system:
When playing demanding games like Watch Dogs, AC4 Black Flag or GTA V, the FPS drops considerably, from 60 to 15-20, from time to time for about 5 to 10 seconds. Afterwards, it returns to the normal 50-60 FPS.
Sometimes pausing the game and returning to it can be used as a workaround.
The only thing I see that could bottleneck is my PSU that can't absorb the juice my CPU + GPU suck so I decided to give a shot at changing it.
What better PSU would you recommend for this system?
I did some research and decided on the Seasonic S12II-620 Bronze 620W.
I'm pretty sure the wattage is enough for my system. But do you think it's an overkill?
Or better yet, is the PSU not the problem here? Should I look somewhere else?
Any help here is appreciated.
Thanks in advance!
CPU - AMD FX-8320
GPU - ASUS Radeon R9 270X DirectCU II Top 2GB
MoBo - ASRock 970 Extreme4
RAM - Kingston HyperX BEAST 8GB (2x4GB)
SSD - Kingston SSDNow V300 120GB SATA-III 2.5 inch
HDD - WD Blue 1TB, 7200rpm, 64MB, SATA 3
Case - Zalman Z3 Plus (4 X 120 mm coolers)
CPU Cooler - Master Hyper 212 EVO
PSU - Sirtec ECO II HPE-450-A12S, 450W, ATX 2.3, PFC active
Thanks in advance!
