Optimus - GT 540M, odd problem. Hardware failure?
jenc
4
I have an odd problem which I have been struggling to find the solution to.
I have just bought an ASUS X93SV (aka K93SV), I5-2410M, GT 540M, 8gb ram.
From the first day I haven't been able to make it swith to the dedicated graphics. I have tried every trick in the book (see below) but it actually gives fewer fps than the built in HD3000 graphics.
First I thought it was a driver issue and it never switched to the dedicate GT 540M graphics. Now I'm finally thinking it's a hardware failure.
At all times, windows and Nvidia control panel has shown it to work correctly. And at no time have I achieved the fps I should. In Dirt 3 i get 15 fps and should get 60 fps. In 3dMark06 I get 4400 with the built-in HD3000 graphics. I should get 7.800-7.900 with the GT 540m graphics, but get 3800-3900. At first it was also 4400, so I thought it never switched to the GT 540M
But I can see from the graphs in "Nvidia Inspector", and sidebar monitoring that the GT 540M GPU works 100% when I run 3dMark06, but it ends up given a score of 3800, which is less than the build in HD3000 graphics (4400) and lot less than it should, i.e. 7.850.
Since I can see it uses the GPU 100% I shifted from thinking a driver problem to thinking a hardwareproblem.
I can see from Nvidia Inspector that it runs at 95c to 101c celcius when it runs 3dMark06. To my knowledge this is hot, but not nescessarily where it starts affecting performance. Someting is, though 🙂 The GT540M idles at 70c-75c celcius when it is not in use and the HD3000 runs (ordinary windows use).
- Does anyone know what the critical temperature of the GT 540M is?
Hopefully actully knows, rather than "I think it's too hot"...
- Does anyone with the GT 540M (who has it working) have temperature readings from idle and work, e.g. from "Nvidia inspector" (there is a graph icon left to the heading "GPU" which gives readings over time).
At one hand I can't think of anything else than a hardware failure. On the other hand that happens so rarely so before leaving my new laptop to repair I like to hear your oppinions.
Kind regards
Jens
To problem sove I have tried
- every Nvidia driver from 268.39 (from ASSU) to recent 280.26
- all Intel graphics driver
- switching back and forth to auto-select and dedicated select of graphics card in Nvidia control panel
- selecting dedicated graphics for PhysX
- running High Performance mode for battery
- installing a clean windows 7 SP1 764bit
- reverting to "Recory of ASUS"
- googling for days
- plus much more
And all the time with the same result. I don't get the expected fps, and always windows/nvidia reports everything if fine.
From googling others who experience problems, it is normally for a specific game, whereas other games work. I haven't seen one single thing actually giving the expected fps's.
What wei rating does your os shows in gaming and aero assesments, your lappy is from asus so if there were any drives utilities by asus remove it and try to run only in generic drivars , mostly asus splended, gammer osd , kernal mode enhance drives causes problems in my case asus splended is curlprit best of luck....
