Optional Case or Chassis
I have the CM 690 II Advanced and it's been a great case, easy to work in, does everything I've needed, would have only been better if the 690 III had been available, really hard to beat a 200mm intake/exhaust for airflow, which these cases have tons of.
If I was to part with this case, I'd be looking at the Fractal Design define r4 blackout or the define r5.
Optional? I presume you mean alternative....
I like some of the Corsair cases... have a look at them? I have a Corsiar Vengeance C70 case which is great for cooling but has no sound proofing at all.... The Corsair Obsidian series cases are classic designs.... always look great....
I also have a Fractal Define case, whcih is another classic look and has great sound-deadening
Bro.. something which within the budget, same as CM 690 III
