Question Orange VGA Light and no output
Jul 5, 2020
I am trying to build my first pc and got everything connected. However when i go to boot it up i get an orange vga light instead of a white one.
My specs:
CPU:Intel Core i7-10700 Comet Lake 8-Core 2.9 GHz LGA 1200 65W BX8070110700 Desktop Processor Intel UHD Graphics 630
MB:ASUS TUF GAMING Z490-PLUS (WI-FI) LGA 1200 Intel Z490 SATA 6Gb/s ATX Intel Motherboard
RAM:G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) AMD 3000 Compatible Intel XMP 2.0 Desktop Memory F4-3200C16D-32GTZR
PSU:Thermaltake Toughpower GF1 850W 80+ Gold SLI/Crossfire Ready Ultra Quiet 140mm Hydraulic Bearing Smart Zero Fan Full Modular Power Supply 10 Year Warranty - PS-TPD-0850FNFAGU-1
TOWER: DIYPC Vanguard-RGB Black Dual USB3.0 Steel/ Tempered Glass ATX Mid Tower Gaming Computer Case w/Tempered Glass Panels (Front and Both Sides) and Pre-Installed 4 x RGB LED Fans (7 Different Color in 3 Mode Control)
MEMORY: Intel 660p Series M.2 2280 1TB PCIe NVMe 3.0 x4 3D2, QLC Internal Solid State Drive (SSD) SSDPEKNW010T8X1
GRAPHICS CARD: ASRock Phantom Gaming D3 Radeon RX 5600 XT RX5600XT PGD3 6GO 6GB (14Gbps) 192-Bit GDDR6 PCI Express 4.0 x16 HDCP Ready Video Card
Have tried it without the gpu as well
Do you have both the 8 and 4 pin power connectors attached to the ATX motherboard in addition to the 24 pin connector?
Check your motherboard manual about this...
