Question ordered a pc but I believe i made of missed something for liquid cooling, did I?
Mar 13, 2019
6
I am not sure but I may of missed something with my order in liquid cooling, can you tell me if I am wrong? If you look below it says coolant wasn't ordered. Not sure if cyberpower automatically adds coolant or will I need to order some and put it in myself.
  • *BASE_PRICE: [+1099]
  • BLUETOOTH: None
  • CABLE: None
  • CARE1: Cooler Master Mastergel Maker CPU-Thermal Compound Optimized for Thermal Dissipation [+10]
  • CAS: CYBERPOWERPC X-Saber 620 ARGB Mid-Tower Gaming Case w/ USB 3.0, Full-Size Tempered Glass Window [-2] (Black Color)
  • CASUPGRADE: RGB Multi-Color 16 color LED 1x interior light strip w/ Remote Controller [+12]
  • COOLANT: None
  • CPU: AMD Ryzen 7 2700X 3.7GHz [4.3GHz Turbo] Eight-Core 20MB Cache 105W Processor [+36]
  • CS_FAN: Default case fans
  • FAN: DEEPCOOL CAPTAIN 240EX 240mm Radiator CPU Liquid Cooler w/ Copper Cold Plate CyberpowerPC 120mm Dual Light Loop ARGB 1200RPM Fans w/ Hub + Remote
  • FREEBIE_CU1: The Division 2 [+0]
  • FREEBIE_SSD: 3TB (3TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD
  • FREEBIE_VC1: Buy 2060 or 2070 and PICK ONE between BFV or Anthem or Metro Exodus [+0]
  • HDD: 500GB WD Blue Series SATA-III 6 Gb/s SSD - Seq R/W: Up to 545/525 MB/s, Rnd R/W up to 100/80k [-2] (Single Drive)
  • IUSB: Built-in USB 2.0 Ports
  • KEYBOARD: CyberPowerPC RGB 7 Color Premium Gaming Keyboard
  • MEMORY: 16GB (8GBx2) DDR4/3000MHz Dual Channel Memory [+60] (GEIL EVO POTENZA)
  • MOTHERBOARD: ASUS TUF X470-Plus Gaming AM4 ATX w/ RGB, USB 3.1, Realtek LAN, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
  • NETWORK: Intel EXPI9301CTBLK Network Adapter 10/ 100/ 1000Mbps PCI-Express [+34]
  • OS: Windows 10 Home (64-bit Edition)
  • POWERSUPPLY: 650 Watts - Corsair TX-M Series TX650M 80 PLUS GOLD Certified Semi-Modular Ultra Quiet Power Supply [+55]
  • PROMOSALE1: Syber M1 RGB 6200 dpi Optical Gaming Mouse
  • PROMOSALE2: CYBERPOWERPC Skorpion K2 RGB Mechanical Gaming Keyboard
  • PROMOSALE3: ZALMAN ZM-HPS200 GAMING HEADSET
  • PROMOSALE4: 6-FT HDMI Flat Cable, V1.4, Supports 3D & 4K Resolution, Gold Plated Connector Cable [+5] (1 piece)
  • SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
  • SLI_BRIDGE: None
  • SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
  • SPEAKERS: None
  • USBX: NZXT Internal USB 6-PORT Expansion Module [+19]
  • VIDEO: GeForce® RTX 2060 6GB GDDR6 (Turing) [VR Ready] [+77] (Single Card)
