Oregon Trail: 16 bit installation for 32 bit game on 64 bit computer.
Rick_OShay1
7
Very recently, I'd have a wave of nostalgia wash over me, and fill me with a desire to play The Oregon Trail again.
Editions #4 and #5 felt extremely dumbed down, so I insist on playing #3.
My PC is Windows 7 and is 64 bit.
The game is 32-bit, but the installation program is 16 bit, and because of that, the installer insists on not cooperating because it's "incompatible".
P.S. No, I can't change the compatibility until the game itself is actually installed.
if your installer is on a cd you probably right. the simple solution (and this is a tease of course) is run Linux with a copy of windows 98 on it. then install the game ), but seriously, since I googled it and found this which to me is exactly your issue
"Much older applications that pre-date Windows 95 will sometimes require a bit more work. 16-bit applications, in particular, are not natively supported on 64-bit Windows 10 because the operating system lacks a 16-bit subsystem. This can even affect 32-bit applications that utilize a 16-bit installer."
go visit this web page they seem to have a work around that might help you .
https://www.groovypost.com/howto/enable-16-bit-application-support-windows-10/
Unfortunately, that website is for someone with windows 10, and 10 is radically different than 7.
Plus, I hate vague instructions. And I can't find anyone who gives precise step-by-step instructions.
I am following the link's steps, but hit a snag at step 6. The picture shows a list of folders, whereas on my computer, they are .img, with the iso avatar. The DOS says that it's "an illegal action".
I do have, and use, WinRAR.
The files contained within said WinRAR are .img, and have the .iso icon.
And wherever I extract the files to, (i.e. desktop), the files remain as .img with the .iso icon rather than as folders like the step-by-step tutorial shows.
Ok, I just found out, despite me seeing them on my WinRAR, the iso files are actually 7-zip, hence why WinRAR is stubborn to cooperate.
Is there a way to change 7-zip into actual WinRAR?
