Question Original fat PS4 model, hdmi signal cuts out randomly after port/IC replacement ?
Dec 18, 2022
Hi, folks!
I am not a professional, so I would appreciate if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so I checked the hdmi fuse, which was blown - replaced it with a fuse from SAD-001 board. Still no picture, so I replaced the HDMI IC from that same board and 2 HDMI filters as well. Replaced one resistor and a diode too, which I saw on a repair video by Andrew Paul. Then the signal was fine, played for half hour, all good.
After a couple of weeks I turned the console on and there was the WLOD again. On safe mode, I changed the resolution to 1080i, since on 1080p there was no signal. The colors were weird, but picture was present. I tried another cable - with that one 1080p worked, but all the whites on the screen were with snowy artifacts as well as the left corner. So I hot-aired the HDMI ic in order to solder any loose joints, and this time it worked fine on 1080p. I thought it was finally OK, so reassembled the unit.
However, after turning on the console, it would go blank screen for a minute or two, then the signal comes back. Works fine for a couple of hours, then goes black/no signal for good. After power off/on again, the same thing happens - the signal randomly drops couple of times, then comes back and cuts out properly after a while.
I would really appreciate if somebody with proper knowledge/experience has any idea what causes this issue. Many thanks!
https://drive.google.com/file/d/1HWNs3aNL1BbznRg7Hd4sbWr6CKylK5ag/view
I've fixed it. For anybody having the same problem - it seems that the Panasonic HDMI ic had one pin loose, I nearly broke it when testing.. It's not that easy to spot a loose connection on the chip, so be careful.
