Os Help with 32 and 64 bit
Lucajones1
68
I have a GA990FXA Ud5 motherboard and an Amd FX 8350. Can I run a 64 bit system even though my mobo is 32GB limit?? The FX line does support 64Bit OS too
Those two things have little to do with each other.
32GB RAM for the motherboard is NOT the same as a 32bit OS.
If you want to use 4GB or more RAM, then you need a 64bit OS.
