OU policy problem
Joe
1,187
Archived from groups: microsoft.public.win2000.group_policy (More info?)
I am trying to apply a GPO to an OU. The users in the OU
get the default doamin GPO but not the OU GPO. I have
looked at DNS and assume that its working since they
recieve the default GPO. I reviewed permissions on each OU
policy. gpresult shows default domain policy being applied
but not ou policy any suggestions on what i am overlooking?
Hi Joe.
Don't necessarily assume dns is configured correctly whenever you have a
problem. Make sure domain controller is pointing to itself as it's preferred
dns server and that the domain computers point to domain controllers running
dns. I would start by running netdiag on the computers that the users are
not getting the policy from looking for failed tests/fatal warnings. Also be
sure you are configuring user configuration and not something like password
policy. Other things to look at are that the user configuration part of the
gpo is enabled, the gpo itself is enabled, the GPO's at a higher level do
not have "no override" configured and have the same settings defined, and
that the users are not logging on a computer that is in an container with
"loopback processing". It is also possible the policy has not propagated
yet. Using secedit as described in the link below on the domain controller
first and then the domain computer can speed propagation of policy. ---
Steve
http://support.microsoft.com/default.aspx?scid=kb;EN-US;227302
http://support.microsoft.com/default.aspx?scid=kb;en-us;810739
"Joe" <jchildress@cofcu.com> wrote in message
news:1957f01c44cd5$310c4810$a501280a@phx.gbl...
Joe,
The GP troubleshooting guide may help too
http://www.microsoft.com/windows2000/techinfo/howitworks/management/gptshoot.asp
You all seem to have all the bases coverd
-Permissions
-Inheritance
-Replication
Do you have any GP's applied to computers or users in other OU's are
those working ok and being reported using gpresult or is the problem
only with this particular OU?
"Steven L Umbach" <n9rou@nscomcast.net> wrote in message news:<di5xc.13750$HG.6748@attbi_s53>...
> Hi Joe.
> Steve
Steven
thanks for help on this. ended up removing OU policy
allowing propogation then re applying all worked well
after that.
Joe
>-----Original Message-----
>Joe,
>-Permissions
>-Inheritance
>-Replication
other OU's are
the problem
>> Hi Joe.
whenever you have a
that the users are
a higher level do
an container with
has not propagated
>> Steve
US;227302
us;810739
OU
each OU
applied
overlooking?
