I have a 1366x768 native res monitor. My PC is an APU (integrated graphics use only) build and I've been using Crimson's "Virtual Super Resolution" to set display higher up to 1920x1080 for a very long time now. But now, I've bought an RX 460, which has 1 DisplayPort, 1 HDMI port and 1 DVI port. My monitor only has a VGA port so I've bought an HDMI-to-VGA Converter/Adapter to connect the RX 460 with my monitor.
But now, whenever I try to set a higher resolution (1920x1080) on Windows Display Settings, it always says "Out of Range" for around 10 seconds and reverts back to normal 1366x768. I've already tried turning Virtual Super Resolution on and off, trying resolution change on both situations, but same result. I've also disabled the APU's GPU component since I will be now relying on the RX 460. It sucks that I'm limited to a resolution even when adding a better graphics processor.
Is this a permanent issue of using a VGA-to-HDMI Converter???
If it helps, here are the specs:
AMD A8-7600
8GB (2x4) DDR3 RAM @1866 MHz
Gigabyte RX 460 Windforce OC 2GB
Monitor: ViewSonic VA1616w
Win10 64-bit
AMD A8-7600
Win10 64-bit
