Every TV monitor has a max resolution and it cannot display a resolution beyond what it was designed for lets say you TV was designed for 1920 x 1080 resolution but your monitor was designed for a maximum resoltion of 1080 x 720 and ur computer settings were changed the o display more than what it monitor can handle but ur TV can.
The simple fix is to go in screen resolution settings of ur computer when its plugged into ur tv and set it to the lowest possible setting then save it and take ur pc to your monitor and adjust the resolution until u think that u can see the screen clearly.
Good luck
