Outlook express and IE printing problem
hank
145
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Am running Windows 98SE and recently I have not been able to
print mail in outlook Express or web pages with Internet Explorer.
Printer is installed and is my default printer. I am able to print
using MS Word and pdf files so must be connected. Any suggestions
or ideas?
TIA
email response not expected but to respond remove .uk at end
TIA
Hank
Delete the printers, then select to Add Printer.
"Hank" <hgreintges@skybest.com.uk> wrote in message
news:kq0if1dd0bbevptnk7dj16jdorb53pkhrc@4ax.com...
> or ideas?
> TIA
> TIA
> Hank
What happens when you try to print? Post any error messages in their
entirety, please.
1. (Re)Install 5.6 Scripting Engine for Win98
http://msdn.microsoft.com/library/default.asp?url=/downloads/list/webdev.asp
2. See http://inetexplorer.mvps.org/archive/answers3.htm#preview_dlg
~Robear Dyer (PA Bear)
MS MVP-Windows (IE/OE) & Security
> or ideas?
> TIA
> TIA
> Hank
Thanks for the two responses. Will try deleting and re-adding the
printer to see if it re-connects it.
If this does not work will try replacement of the IEPEERS.dll
file as one person suggested. BTW is this file sensitive to the OS
like would my iepeers.dll on WindowsXP work on my friend's
Windowsm98SE?
It is on a friend's machine so I was not had a chance to see
it yet. He does not report any error messages just on selecting print
in IE or Outlook Express nothing happens. The printer window does not
open also.
On Tue, 9 Aug 2005 20:22:17 -0400, "PA Bear" <PABearMVP@gmail.com>
>entirety, please.
TIA
Hank
Windowsm98SE?
open also.
>entirety, please.
TIA
Hank
