Hello everyone. 2 days back all of a sudden my keyboard stopped working. I restarted my pc after re plugging and it gave me a warning "Over-current detected on usb device, motherboard will shut down in 15 secs"
So I disconnected everything, opened the case removed all USB connectors, case fans, front panel buttons, everything non mandatory. Still kept going. Mobo VGA Light is turning red on the process. (My gpu is Asus rog strix OC 3070 ti) (psu is seasonic 650w gold)
Than I took the pc to a repair shop thinking my mobo got broken, most probably one of the io usbs. But it worked perfectly fine there! The pc is working outside the house. It seems there is an issue with the house electricity. But electricians can not find anything and they couldnt fix it nor understand what is the problem. Did any of you encounter such thing? Or do you have any idea how to solve this? I am hopelessly looking for a Solution.
I am in Qatar atm and standart voltage is 240v here. I bought the pc parts in a 220v country if that matters. Electricians checked the actual output of voltage and the result is 247v if that is related.
