Over Current Detected System Will Shut Down In 15 Seconds, HELP!!
CloneNiNJA
12
okay so here is the thing last night me and my brother were play games pretty late, then my sister runs in trying to tell me something and knocks my drink of Pepsi down into my computer, I cleaned up most of it and there restarted it to make sure and it worked fine.
but now the next day when I try and turn it on I keep getting the message over current detected system will shut down in 15 seconds
I have tried unplugging the front ports from the motherboard but nothing really worked.
All help is appreciated, I hope i can get this fixed soon.
Thank you
yes thanks for the advice ill try that now, but I'm confused as to why my computer was working the night that it happened and then the next day it doesn't???
It could be that it seeped further into your PC as time went on, plus becoming sticky. Soda that's dried on solder joints is a bad thing. I'd check your parts over carefully and clean before powering on again. Just some rubbing alcohol and Q-tips should suffice, but again you won't know for sure until you check.
Thats what i have been doing it only went on the mobo and the case ive cleaned it all up but it continues to say current setected shutting down, and i dont understand because it went nowhere near any usb ports
Tried unplugging everyting didnt work not sure why i have notging plugged in an i stll get the error message
I have taken the battery out, how long do i leave it out?
