this is my first ever pc. I have been using all kind of macs for years, but enough is enough from this company charging so much and offering so little.
this is my build that I have been planning and saving for it for months now. I read and watched a lot of youtube videos about almost every part in my build. However I'm still worried about if it is gonna actually work together. I checked https://pcpartpicker.com. and the only issue they show is this:
The motherboard M.2 slot #1 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled.
I think I get it but I just need a conformation from you pc building experts
also I want you to kindly check the whole build as if it will work and if you have some advices(if there is a way I can save more money) , as you know it is costing me a lot.
the second question is:
does the different kinds of brands and mods of the same GPU really make a difference, as their prices seems to vary a lot. I just got the cheaper one, but is it really worth it to take something with an extra fan on the GPU for 300$ more?
and the last question is:
I got some zip ties but is there anything else I need or I might need in my build because I live in the other side of earth and returning or replacing something gonna be very hard and costly.
I will be using it for working (video editing in (adobe Premier, After Effect), 3d rendering and animating and modeling mostly in cinema 4d and Blender) and also will be playing a lot on it.
small note:
I will be replacing the original case fans with the corsair RGP fans (#3 120 for the front, #1 140 for the back) and I will be connecting them with an RGP strip to the Commando Pro so I can control them all via software.
Thanks in advance
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($499.99 @ Amazon)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler ($139.99 @ Newegg)
Motherboard: Asus - ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard ($235.99 @ SuperBiiz)
Memory: Corsair - Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 Memory ($262.99 @ Newegg)
Storage: Samsung - 970 Pro 1 TB M.2-2280 Solid State Drive ($347.99 @ B&H)
Storage: Toshiba - P300 3 TB 3.5" 7200RPM Internal Hard Drive ($95.84 @ OutletPC)
Video Card: EVGA - GeForce RTX 2080 Ti 11 GB XC ULTRA GAMING Video Card ($1299.99 @ B&H)
Case: Cooler Master - MasterCase H500M ATX Mid Tower Case ($188.98 @ Newegg Business)
Power Supply: Corsair - RMx White 850 W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($98.89 @ OutletPC)
Case Fan: *Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.25 CFM 120mm Fans ($109.43 @ Newegg)
Case Fan: Corsair - LL140 RGB LED 51.5 CFM 140mm Fan ($31.17 @ Amazon)
Other: CORSAIR Commander PRO
Total: $3461.14
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2019-02-08 19:41 EST-05000500 |
small note:
Thanks in advance
Total: $3461.14
