Under a stock cooler, no way.People here told me the best B450 VRM is the Tomahawk Max, and I want the 3800x. Can I get 4,4-4,5 GHz all cores with the B450 Tomahawk Max and the stock cooler? Do you recommend another B450 motherboard? Is neccesary a x470 motherboard? What do you recommend?
Ok, can you recommend me something please?Under a stock cooler, no way.
A 480 to 360mm AIO cooler or https://noctua.at/en/nh-d15 if you want those frequencies.Ok, can you recommend me something please?
Do you recommend another B450 motherboard?You need good low latency RAM that can overclock to 3800 with low timings. 3600 CL16 samsung b-die has a good change of getting there.
An expensive option is https://www.gskill.com/community/15...Memory-Kit-for-AMD-Ryzen-3000-&-X570-Platform
Yes, I have that link, that work is impressive, but I need opinions of overclockers.I don't really recommend boards but lots of information can be found here. https://forums.tomshardware.com/thr...yzen-cpus-sortable-comparison-tables.3110172/
