OverClock AMD A8-3820 Problem
ixins23062001
Hi! I have a little problem, I'm trying to OC my CPU "AMD A8-3820" Stock speed 2.5 GHz boost to 2.8Ghz . I went to the Bios and set it at 3.0 GHz windows started normally and I was getting the same results in Cinebench15 , Task Manager shows the speed to be at 2.79 Ghz while CPU-Z and AMD OverDrive at 3.0GHz . My motherboard is" BIOSTAR Group A55ML" ( I know old stuff). Thanks in advance!
272 is the highest(with stock and with it was set at 3.5 GHz) but the speed of the CPU was not that much cuz I believe it would show a better score, only the CPU ,, I've already OC my GPU (GTX 680)
