Overclock AMD K6 200Mhz Help
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    CPUs
G
Guest
Guest
I have a AMD K6 200Mhz processor that I would like to try to overclock a bit. I am having troubles finding a guide on overclocking that talks about this specific processor. Does anybody know where I can find the info I need? Perhaps you have some suggestions...such as what is the maximum speed I should try and such.
Thanks.
-Dan
is that the fastest that I can safely go with this processor even if I have wicked cooling and a nice MB?
Maybe as high as 275 with the right bus speed and multiplier. I recommend the highest bus speed your board can support, with an appropriate multiplier to get it between 240 and 280.
Cast not thine pearls before the swine
