Spectre694 :
AuroraHD :
I was using amd overdrive instead of bios. But I can't really trust overdrive. And I'm using GTX 760. I'm using overdrive for the temps. Don't know if I can trust that either
Good that means the iGPU doesn't need to be OC. I wouldn't trust overdrive personally. I would get CPU-Z and HWmonitor and make sure everything (voltage temps) is matching up just to be on the safe side as something with your setup sounds off.
We'll I did something really weird this time. I overclocked to 3.4 in bios, the added .2 MHz in overdrive yesterday. But then my system didn't boot up just today
😛. luckily, I just have to force shutdown my comp twice for my computer to recognize something is wrong here. So that, I am not doing again
😛. I am wondering, is it more performance effective if I OC in bios? Because I haven't seen too much of a performance boost. In 3.4 ghz from bios, I get 70 frames in full screen on GTA 4 but with 3.6 with overdrive I get 90. Should I use overdrive? Also, the overdrive OC settings don't save after a restart
