I created a post back in November which is located here: http://www.tomshardware.com/answers/id-3559133/7700k-83c-spike-temps-deepcool-gammax-400.html
I now have my chip delidded and binned, upgraded to a Corshair H115i cooler, added more efficient fans, and I'm running a push pull config on my raidator via two 4 (four) 140mm corsair fans. Since I had my computer apart, I also added some WideBeam UV/RGB lights and UV reactive cable extensions. Also added some more RGB ram and a couple Hybrid Hardrives so I don't fill up my M.2 NVMe SDD. So I really like the way it came out.
OH, BY THE WAY, my temps are about 35-40 degrees while idle with an ambient temp of 24 degrees C. While gaming, my temps go up to around 50-55 degrees. In comparison, with the same game on my old air cooler, my temps would reach 75-78C. These are stock voltages with XMP enabled. I haven't applied any real overclocking voltages yet.
I wanted to get some input about the binning part. Silicon Valley sent me back a note saying:
"Your CPU should be stable at 5.1 GHz when using a 1.437 Vcore with a -2 AVX offset."
My question is, are those the only two settings that I should change? Set it and forget it?
BEFORE Delidding & Binning with Air Cooler:
After Binning & Delidding with AIO:
FULL SYSTEM SPECS:
INWIN 805: Front Panel Modified for Higher Air Flow Rate
Processor: Stock Clock Rates & Voltages. KABY LAKE INTEL 7TH GENERATION CORE I7-7700K
Cooler: Corsair H115i 280mm Radiator with 4 Corsair 140mm Fans Push Pull Configuration
MONITOR #1: SAMSUNG U28E590D 28 INCH UHD LED-LIT MONITOR WITH FREESYNC SUPPORT 3480X2160
MONITOR #2: ASUS VE278H 27" FULL HD 1920x1080 2MS HDMI VGA BACK-LIT LED MONITOR 169.00
FAN HUB: SILVERSTONE PWM FAN HUB SYSTEM CABLES (CPF04) 14.44
RAM: 32 GB 4 QUANTITY - XMP Enabled CORSAIR VENGENCE RGB 16GB DDR4 3466 (PC4-2700) C16-INTEL 100/200 SERIES PC MEMORY CMR16GX4M2C3466C16
Graphics: ASUS GEFORCE GTX 1080 8GB ROG STRIX GRAPHICS CARD (STRIX-GTX1080-A8G-GAMING)
Keyboard: Corsair Strafe RGB
Mouse: Logitech G502 Proteus Spectrum RGB
SSD: SAMSUNG 960 EVO SERIES - 500GB NWMe M.2 INTERNAL SSD (MZ-V6E500BW)
HDD #1: 2.5" Hybrid SSHD Segate 1TB (7200 RPM I think)
HDD #2: 2.5" Hybrid SSHD Segate Firecuda 2TB (7200 RPM I think)
FANS: 1 QTY ML 120mm as fan exhaust in back 75 CFM Max, 2 QTY Corsair HD120 in bottom as intake, 4 QTY LL140 has Radiator intake fans in the front
Power Supply: EGA SUPERNOVA 650 G2 80+ GOLD 650W FULLY MODULAAR EVGA ECO MODE 7 YEAR WARRANTY FREE POWER ON SELF TESTER 220-G2-0650-Y1 | 90% EFFICIENCY
Lights: CableMod WideBeam UV/RGB Strips, one 60cm strip and one 30cm strip.
Green Cable Extensions: Amazon UV Reactive
Radiator Hose & Wire Mod: PrimoChill Anti-Kink Coil
FULL SYSTEM SPECS:
