I can barely boost my GPU above +100Mhz. However I saw someone with similar problems, and one of the persons in the thread reacted saying he should use 2 cables with 2x6/8 instead of 1 cable with 2x6/8. Is this right?
My reaction there:
"Wait, I'm currently using 1 PCI-e cable that goes from 1 8 slot PCIe to 2 6/8 slots PCIe's. (2 x male 6+2 pin to male 8 pin)
Like this: https://imgur.com/a/5beNyMP
Came with this PSU: http://www2.seasonic.com/product/m12ii-750-evo/
Are you saying the power is being split between those 2? So I should use 2 x8 pins on the PSU, only using 1 of the 6/8 pins on each?"
So basically my question comes down to this: Should I use 2 of these cables https://imgur.com/a/5beNyMP ? If so, I know where my OC problems comes from
Lucky_SLS :
2 8 pins can give 375w of total power.
1 8 pin gives 150w max. The mobo pcie connection gives 75w.
The 2080ti reference design is 250w tdp. Overclocking can easily take 350-400w.
But mind you, the auto oc scan stresses the gpu to find max stability at a given oc. Gaming loads for that particular oc will be typically 50% of that load and increases depending on that particular scene graphics rendering.
My reaction there:
