Overclocked Asus Z97-A not booting - PSU issue? Please help!!
PDM4518
5
I've just bought a pre overclockd bundle comprising Intel Core i5 4690K clocked & tested to 4.6Ghz, Asus Z97-A board, 2x 4GB Corsair Vengance Pro 2133MHz
I'm using the following with it:
OCZ GSX 600w PSU
2x Nvidia GTS 8800 SLI (old, I know!)
1x 128GB Sandisc SSD
1x 64GB Crucial SSD
2x DVD-RW
6x Case fans
It won't power up at all. None of the board led's are on & only a couple of case fans work. There are no audible warnings. Just nothing.
I'm confident it's all been put together ok & it came with the memory, cpu & fan fitted. All well packaged. I've built several systems before so I'm sure it's all correctly fitted.
When I switch it on the psu illuminated fan light flickers as if it's struggling to power up. I removed the SLI cards and the PSU fan light stayed on but dimmed & brightened constantly.
Is it my psu that's too weak to run this system? It's not faulty as it was ok with my existing rig.
Any help would be very welcome - thanks!
