[SOLVED] Overclocking and Power consumption
Ryan3996
24
Hey all I’m fairly new to all of the PC builds and still learning I wanted to build my pc myself but instead chose my components and had a company build it (PC specialist) , anyway my question is on my current build I have a 350w Corsair PSU VS-350 and a GTX1660ti GPU I noticed that the GPU is overclockable and wondered if I’d need to upgrade my PSU for overclocking it ? I’ve seen a few videos that don’t touch the actual voltage to the GPU but the GPU memory and GPU core speed , providing I only do this and not touch the voltage will my PSU handle a slight overlook on my GPU , thanks in advance , Ryan 👽
It might, it might not. That's a power supply suited for home/office PCs - easy, steady, low power loads, and not a gaming PC - difficult, wildly fluctuating high and low loads.
If nothing else, the Corsair VS shouldn't blow up on you, but if you start crashing/freezing, then you will know why.
What is the cpu?
What is the exact model of the 1660Ti?
i5-9500: 160w(as a worst case scenario, on Prime 95: https://bit-tech.net/reviews/tech/cpus/intel-core-i5-9500-review/6/)
1660Ti: 120w
= 280w, but we need to include some extra headroom for everything else, so let's add 20% of this total on top...
=336w.
The VS350 has just 300w on the +12v rail... I'd say you're more likely to crash trying to OC.
Corsair CX550, CX550M, TX550M
Seasonic Focus, or Focus Plus 550
EVGA Supernova G3
