Overclocking APU or Memory Speed?
Warhorse99
35
I recently completed building a desktop with AMD A10-7850K and Asus A88X-Pro Mobo loaded with 4x4 GB Mushkin Enhanced Redline 996996F 2133 9-11-10-28 memory.
I can OC the APU to 4.1 (from stock 3.7) but when I push the memory past 1866, it goes down with almost no load.
Am wondering if it is a board or a bios issue or is this the best I can get with this setup?
Don't overclock the RAM, really pointless in my opinion. It might give you 1-2 fps difference (Which is actually proven)
Just overclock your APU to 4.1GHz, 400MHz overclock should give you a really noticable performance increase.
That isn't the best DDR3-2133 kit with those timings. Is it at least a 1.5V kit and not a higher voltage kit? If not, then I would expect stability problems when trying to get a good clock rate out of it. If it did work at DDR3-2133 without problems, then it would be a nice little performance boost in games at around 5% to 8% higher gaming performance. Nothing huge, but not bad.
Games will favor high frequency over low timings, although low timings do help a little bit.
Thanks Sandstorm for the quick response. I have noticed the performance difference when OCing to 4.1 and with 1866 memory speed everything is stable and no heat issues, even under load.
This will be my BIOS standard setup.
@Warhorse99, great :)
@blazorthon i am curious, where did you get those numbers from than?
I have seen some benchmarks quite some time ago with different RAM speeds matched up against eachother. (I could probably find them if you want to see em)
It is a 1.65v kit.
http://www.newegg.com/Product/Product.aspx?Item=9SIA85V3R95359
It says I am running at 1.65v on all 4 slots
The benchmarks you're thinking of probably use discrete graphics cards, which have high bandwidth, low latency VRAM. So system memory bandwidth isn't as important. Integrated graphics don't have VRAM, they rely on system RAM. So system memory bandwidth/latency becomes more important.
I looked at Tom's own benchmarks for APUs with different memory memory speeds up to DDR3-2400. On average, they saw the performance go up about two thirds of the increase in bandwidth for each step up in memory frequency with slight diminishing returns. I've also read other such tests on other sites over the years.
Didn't even think about that. Very true, and ofcourse makes sense.
I have set my voltage at 1.4 and APU OC at 4.0 and now am stable running memory at 2238.
So far so good, even with stress testing
