Hello, I've been messing around with intel's turbo boost technology on BIOS for a while and at first I recognized I had a turbo boost up to 3.9 GHz as it was advertised when I bought it. When I turned the turbo boost into manual, it automatically set the multiplier to x41, which with the 103mhz bus speed let my CPU reach over 4.2GHz. Upon discovery, I of course left my intel stock cooler to dust and did research and in the end bought the hyper 212 evo. This left me with an insanely stable CPU speed I've been using over atleast the 1 and a half years with the cooler not letting the heat nearly get to high enough for a problem to occur at all.
I'm wondering if anyone else has done some "overclocking" using the intel turbo boost, or they prefer to overclock manually.
"Intel® Turbo Boost Technology can automatically run the processor core faster than the marked frequency if the part is operating under power, temperature, and current specifications limits of the thermal design power (TDP). Performance of both single and multi-threaded applications is increased."
From the common questions answered on Intel's website again;
Can I specify the maximum Intel® Turbo Boost Technology frequency?
No. Maximum frequency for processor function is automatic and dependent on working conditions.
So then how has it found out my max multiplier can be x41 when the max is supposed to be 3.9ghz?
Thanks in advance.
Thanks in advance.
