I have the trust gxt 277 notebook cooling pad with a 20 mm fan, but it seems it does not change much the pc's overall temperature (cpu and gpu).
So I know these are supposed to be connected to a usb port with an output of 5V@ 0,50 A.
I found a powersubbly with an usb cable attached from another device and hooked it up to the cooling pad.
The output is 12V @ 1,5 A.
The fan runs quite a lot faster and this does affects the temperature of my laptop.
My question is, is this safe? should I be doing this or will the fan 'burn out'?
