Type75 Reputable May 6, 2014 123 0 4,710 May 12, 2014 #1 Due to budget, I am not going to overclock right away because I do not have a water cooler. Is it possible to remove the Heatsink and Fan to replace with a water cooler?
Solution clutchc May 12, 2014 Yes, that's how you do it. You can OC w/o a water cooler. Good air coolers start around $40. Check out the Cooler Master 212 EVO.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 May 12, 2014 Solution #2 Yes, that's how you do it. You can OC w/o a water cooler. Good air coolers start around $40. Check out the Cooler Master 212 EVO. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 12, 2014 #3 Depends on what type of case you have , there are different variants of water cooling. Upvote 0 Downvote
Type75 Reputable May 6, 2014 123 0 4,710 May 12, 2014 #4 Depends on what type of case you have , there are different variants of water cooling. I am getting the HAF X. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 12, 2014 #5 You won't have problems. Upvote 0 Downvote
