Overclocking fan+silent for amd fx 6200
Hawkz3r
15
Im looking for a good fan who is good for overclocking but still silent and the price sould not be skyhigh :pt1cable:
http://www.nzxt.com/product/detail/109-guardian-921-rb-case.html#
"CPU COOLER CLEARANCE 144.4mm (with fan) 169.4mm (without fan) "
I am guessing here it refers to a side panel fan.
Noctua D15 is 169mm
http://www.noctua.at/main.php?show=compatibility_gen&products_id=68&lng=en
D14 is 160mm
http://www.noctua.at/main.php?show=productview&products_id=34&lng=en&set=1
hyper 212 evo is 159mm
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
You would have to remove a side panel fan for them to fit, and they will be tight.
Noctua D15 is 169mm
D14 is 160mm
