Overclocking GA965P DS3 with intel E6400- HELP!!
bubbatran209
82
Does anyone out there have a GA-965P DS3 board with the core 2 duo E6400 clocked at least 3GHz with 2gb of ddr2 corsair and stock heatsink that is stable. I would love to get the specs.
Thanks
The problem with that is that someone else's specs may not work for you. So many variables ...
You should learn to do this yourself - if only for next time you build a system.
Some help:
HOWTO: Overclock C2Q (Quads) and C2D (Duals) - Guide v1.6.1
http://www.tomshardware.com/forum/240001-29-howto-overclock-quads-duals-guide
Core 2 Quad and Duo Temperature Guide
http://www.tomshardware.com/forum/221745-29-core-quad-temperature-guide
http://www.tomshardware.co.uk/forum/245679-11-guide-overclocking-ds3l-updated-2008
The third link is for a P35-DS3L motherboard, but the Gigabyte BIOS's are similar.
