Overclocking GTX 1080 Crashes at low temps for some reason help
Fir3dog
41
I overclocked my gtx 1080 with +160 core and +250 mem and it crashes at like 54C temp sometimes when i run a benchmark its like it will becomes unstable and the benchmark crashes even if its very cool please help most people say they can get it to +190 core and +400 mem and they say they cant get to +200 core because there driver crashes.
I have a Zotac GTX 1080 Amp Edition.
Search other forums especially with your specific video card model and voltage as search tags.
I have EVGA 1080 SC so I cannot advice you on it.
On mine I've o/c to +150 GPU and ~350 Mem. with Power target max. of 120%. But this it from EVGA's own O/C software.
No idea if it will support your card.
Do you have enough power to feed it? Plus it's a lottery of your GPU, whether or not it can o/c to higher frequency.
Try to overclock in small increments would be my advice. Also crank your voltage, however be very careful with this settings. You can literally fried your GPU.
how much voltage would you recommend to stable things out? never messed with voltage before.
