I want to overclock my computer and dont know how to use the software that came with my motherboard for OC'ing. Here are my specs.
Gigabyte K7 Triton GA-7 VM400 M
AMD Athlon XP 2400+
Windows XP with SP1
512MB DDR RAM
Radeon 9200 SE by Sapphire
SB Live! Value
80GB Maxtor Hard Drive
Like i said it came with software for the motherboard to OC it but I dont really know how to use it. Its is called Easy Tune 4 if that helps. Is there another way and if there is, How exactly do i do it. I need full details if anyone has the time.
Thanks alot
Sammy
"Follow me, Lead me, or get the hell out of my way!"
Genral Patton WWII
AMD Athlon XP 2400+
Windows XP with SP1
512MB DDR RAM
SB Live! Value
Thanks alot
Sammy
Genral Patton WWII
