Ok I got my new system up and running. did my 12+hr burn in all at stock using dual sessions of prime95, no problems. I followed Wusys guide for OC'ing my E6400(thanks alot btw). Here is my problem. I cant seem to get above 395 FSB without prime95 failing after a few mins. Any suggestions? I made all the changes suggested in wusys guide. I even tried upping the vcore to 1.45 and then to 1.5 with no luck. Another thing i noticed is that my cpu usage isnt always pegged at 100% when running dual prime95. It will ping png from 50 to 100. I have been using PC Wizard to monitor my temps and they range from 32-33c, i dont see much change even after a 8hr torture test, when in the bios the temp is the same as pc wizard says it is. Is there a better program for this? Here are my exact system specs
Mobo:GA-965-DS3
CPU: E6400 With Thermalright Ultra-120
Vid: 7600GT With Kuformula VF1 cooler
Mem: 2gb DDR2 800 Cas4
Here is a couple CPUZ screenies i took
Mobo:GA-965-DS3
