Good morning Tom's Hardware users.
This is my second attempt at a response for this issue so I'm hoping I can get some answers this time around. Also just to mention I'm pretty new to overclocking so please keep jargon to a minimum.
I have just started to overclock my graphics card after successfully pushing my CPU from 3.4 to 4.4Ghz. All was fine and I managed to find my maximum VRAM and core clock speeds on my Graphics card before I started having issues (Core clock stable until about 1050Mhz and VRAM stable up to 1400Mhz)
Now when I started to try and combine the two and find a safe and stable middle ground so to say, I have had loads of instability and this crazy screen flickering issue where the programs are still running (I could here youtube still playing videos) but my screen looks like a TV with static.
With my settings at 1000Mhz on the clock and VRAM at around 1300Mhz it passes Heaven/Valley/3D Mark and playing Metro Last Light with everything cranked up without a hitch, but I left my computer on over night playing youtube videos and when I woke up the screen was completely glitched.
So I'm really just wanting to know if this is an issue that can be fixed or do I simply just need to lower my clocks and settle for a much lower overclock. My specs are as follows.
Graphics card: AMD HD 7950 Sapphire Vapor X
CPU: i5 3570k
PSU: Corsair 630 watts.
RAM: 2 x 4GB @ 1300Mhz
Any help is appreciated.
*EDIT* Forgot to mention that my tempretures have not exceeded 62 degrees under 100% load even on the higher clock speeds.
CPU: i5 3570k
