Hi Everyone,
I got a new E2220 CPU 2 days ago and i was somehow forced to overclock it because when i put it in my system instead of running at its default speed of 2.4Ghz my Bios was detecting it at 1.6Ghz... Maybe because my previous cpu was 1.6ghz but i dunno..
So, after reading the tutorial here, i decided to overclock it to 3.2 ghz as i've read that it should be fine with this speed
When i overclock it to 3.2 ghz, it works without any trouble: I played gta4 for 5 hours straight on and i ran OCCT CPU:Linpack test for 5 hours and it passed the test without crashing or anything. I've even run orthos for 5 hours and it didn't detect any errors.
But after a cold start,i.e after its been shutdown for long a while and restarted, It starts behaving weirdly:
- Yesterday, my mobo simply didn't apply my new overclocked settings, everything (voltages,multipler,etc) went back to normal and it obviously didn't past POST.
-Today, new problems : My overclocking settings were good in bios but it gave me a bluescreen just before logging into vista. So, i had to reduce my clock from 3.2 Ghz to 2.4Ghz then it started normally. And then after it started normally, i changed it back again to 3.2 and now its working perfect again.
Here are the hardware connected and some overclock info:
CPU: E2220. It runs at 30 degrees passively and upto 60 when on full load.
Mobo: Gigabyte GA-P31-DS3L
RAM: CORSAIR TWIN2X4096-6400C5DHX
512MB Xpertvision 9600GT
1*200Gb Seagate and 1*250 samsung HDD
Winpower 650W PSU
1 DVD RW drive
Here are some screenshots :
If you've read till the end of this post, congrats 😉 and thanks for reading 😀 ....This sounds like a very complex problem to me. I hope it can be solved.
Winpower 650W PSU
1 DVD RW drive
