[SOLVED] Overclocking monitor
I don’t believe there is any chance of damage, I believe it means that the 165Hz is not 100% guaranteed.
However I highly doubt you could tell the difference. Try dropping to 120Hz and see if you can tell the difference from 144Hz. If you can’t tell the difference loosing 24Hz you won’t notice adding 21Hz.
