Overclocking my 8600k with the hyper 212 evo air cooler
justin_162
Commendable
Jan 3, 2017
17
Hey guys I was wondering if anyone has some safe recommendations for a safe overclock that won't overheat my cpu. I have an 8600k on the asus strix z370e motherboard. I'm running a hyper 212 air cooler which ik isn't the best. And recomendations on a safe overclock for most chips. Ik that each chip is different.
hellraiser06
709
131
A few questions for you:
1) What are the rest of your PC specs?
2) Are you gaming on this PC or something else?
3) What are the current temps and clocks of your CPU and RAM?
Tyler Paul_1
182
31
every single chip is different so its down to the quality of the silicon your processor was made from which is random.
My personal opinion is to go as far as you can sticking to recommended voltages and temperatures.
High voltages are the main killers of chips so be careful.
Any temperature below 75 is great when overclocking.
justin_162
Commendable
Jan 3, 2017
17
The rest of my system is a gigabyte windforce 1070ti and 16gb of ddr4 2400mhz ram with a evga 80+ bronze power supply. I am gaming on this pc but I'm also streaming a bit and I use music production programs and Photoshop. And my for my current temps. The highest I saw was 89c when stress testing it with prime 95 on the small ffts setting for about 5 minutes and 60c on the blend test
Tyler Paul_1
182
31
i believe the blend test is the most accurate to represent actual temperature. Although, 89 is quite high i would try some games to and monitor how hot it gets.
justin_162
Commendable
Jan 3, 2017
17
I Havent touched anything to do with the cpu yet. i was wondering what is considered safe on the majority of 8600k's with the cooler i have
Apr 29, 2018
Hi man I got no answer for your question but wanted to ask you if you had any clearance problems between your ram and the cpu cooler? asking because i have same mobo and im gonna order the same cooler, thank you
Similar threads
