Overclocking my 9950 BE Need advice
Jesse20James
20
Looking to OC my 9950BE and im not sure where to have it at. I have pretty good airflow and only have a stop CPU cooler so im somewhat limited there. What do you guys think I should have it at 100% stable that is...
I was thinking the mulitplier at 15/15.5? 3000mghz
Voltage...not sure if I should mess with that....
leave FSB at 200
What do you guys think?
doomturkey
430
Ya your gonna want 200mhz x 15 = 3ghz. If it boots up stable and passes torture testing, you won't need any extra voltage. If it doesn't do either of those, add a little voltage, generally I like to add +.05V. If its stable like that, leave it. If not, continue adding voltage until it is.
Also, you need to make sure your temps are in check. I wouldn't let that CPU go much past 55C, 65C is the highest I would let it go.
Jesse20James
20
65c Under load correct? in stock it idles at about 35C and really havent looked at it when playing crysis or something like that and thats with Qfan enabled(smartfan). Is there a great utility that u can dl that monitors ALL your pc's temps aside from the bios and single hardware utilities?
Thanks,
Specs:
OS:Vista Ult 64
MOBO: Asus m3a78-t 790fx
CPU: AMD Phenom 9950 BE
RAM: G.Skill 2gb
GPU: Sapphire 4870x2
PSU: PC Power and Cooling 750W SLI
HD: 250 GB WD
Case: Antec 900
Drives: CDR-DVD 52x
dagger
Splendid
Mar 23, 2008
5,624
Use prime95 for stress testing. Stress at least an hour. Ocers typically burn for 6+ hours. Use small fft.
http://files.extremeoverclocking.com/file.php?f=103
Monitor temperature:
http://www.alcpu.com/CoreTemp/
G
Guest
Guest
I'm having trouble OC'ing my 9950 BE aswell, I can edit the multiplier to 3ghz (what i want it to run at) but as for voltage options i only seem to b able to select, 1.1, 1.2, 1.25 and auto. I put it to 1.25 and 3ghz on the multiplier but it fails on restart, its done this with every combination of voltage and multiplier(between 2.6(stock) and 3.1). its rather annoying and is there anything i can do with it? do i need to play around with FSB speeds? the mobo ive got is an Asus M3N78-VM which would be considered a budget board at £50 (call it $100) but if the functionality is there i cannot see why i shouldn't be able to OC my ship :(. any advice would be much appreciated.
First of all, all hardware is different and of varying quality, just because someone gets a certain OC does not mean you can get the same, you may get worse or even better, That Said.
I'm using aftermarket CPU air cooling, a Zalman CNPS9700 LED.
Vista Home Premium 64
Its very important to MANUALLY set your memory voltage and timings, to whatever they should be!
Presently I'm running a 16x multiplier @ 1.4250v Vcore, however I'm also running a highly modified case with excellent airflow, my GPUs are separated from the CPU section.
The GPUs do not contribute heat to the CPU section, and that makes a serious cooling difference!
Case Airflow is very important, as to what you can attain on an airflow setup!
Here are my specs:
AMD Q9950BE
ASUS Crosshair II Formula M/B
Corsair Dominator TWIN2X4096-8500C5D 4G = 2 x 2G
BFG 8800GT Bios Flashed to 726/1819/1003 2 in SLI
Creative Extreme Gamer Fatal1ty Pro
Seagate 500G SATAII
Here are my M/B BIOS settings [Caution: Doesn't mean you can use the same, this is shared, Use At Your Own Risk Actual Settings]
9950BE OCd to 3.2G idles @ 41c
Overclock Features set to > Manual
CPU Freq > 200
CPU Multi > 16X
K8 NB HT Speed > 2Ghz
K8 NB HT Width > 16 16
Pci-E Clock > 100
CPU-NB Multi > 10X
Vcore > 1.4250v
DDR2 Voltage > 2.100v
DRAM Configuration for Corsair Dominator
Memory Clock Frequency > DDR2 1066
Tcl > 5
Trcd > 5
Trp > 5
Tras > 15
1T/2T > 2T
Gang > Enabled
Remap > Enabled
Skew > Auto
CPU-Z is reporting Core VID as 1.250v that is a CPU-Z error, the Core VID is actually 1.4250v
Hope this helps someone! Ryan
