Overclocking Problems (noob)
Foxy999
46
I am having trouble overclocking my computer, here's my set up:
Winfast NF4SK8AA motherboard
Athlon 64 4000+ (2.4ghz)
G.Skill DDR 400 (pc3200) (2x1gb)
I am having trouble getting a stable system when overclocking. I want to achieve around 3ghz with this and I know it is possible with my cooling.
My CPU multiplier is set at 12 and my CPU is set to 242 for now which is about 2.9ghz. And my cpu voltage stays around 1.36.
My question is: What should I set my memory speed to? I do not know too much about overclocking at this high of a level. My system blue screens a lot when I set my cpu over 240 and I know that is because of memory.
I am not sure what you mean, I do not understand memory in overclocking. I have read about it but I still do not understand.
If I set my memory to a lower speed like 100mhz and I have my HT multiplier at 5x, my computer will still run unstable at ~240 (12x).
I have read the article about overclocking AMD64 processors and it doesn't help it seems like it is for more advanced overclockers....
if the memory is unstable in an overclock you have two options up the voltage which i don't care for personally, but many do. Or you can relax the timings which means to increase them generally i only mess with the first 4 settings and leave the rest alone.
When I overclock I do one thing at a time. I'll set the memory timings high and the speed slow so there is no way they can be an issue until I'm done with the cpu. Then I will go back and bring the memory up to par.
Is there a program that can do this? Because I cannot do it in my BIOS
it's under dram configuration you have to switch from auto to manual then pick your settings my hand
imho
you shouldn't overclock until you learn to find and read an mb owners manual
I did look under dram configuration and it only allows me to select from 100mhz, 133mhz, 166mhz, and 200mhz. It's not like there are multiple settings to change in the configuration.
