Overclocking problems with FX8320 explained inside.
memphis_212
117
It seems when I overclock (yes being kinda a noob) my system lags or is throttled and a 4.5ghz boost is switched to (7-20x) randomly when needed and seems to jump cpu up when needed but give me what looks like a lag spike....
Even in auto oc with amd overdrive or onboard options (m5a99fx pro r2.0 fx8320) it hangs like 2-3 seconds when i type in games. (internet router not the issue)
PS
power saving cie/apm/etc turned off.
Specs
corsair h100i
fx 8320
ripjaws 2400 4gbx2
ASUS m5a99fx pro r2.0
ASUS Strix Geforce GTX 970
Antec HCG 850m
Corsair Carbide Air 540 case (TONS OF ROOM + AIRFLOW)
two front 120mm fans intake
1x back 120mm fans out
2x 120mm fans on rad top of case pushing air out
Guide I followed.
http://www.overclock.net/t/1348623/amd-bulldozer-and-piledriver-overclocking-guide-asus-motherboard
I am confused it lags even on flashed bios sometimes and CPU goes 7-20x ratio but still should not lag on stock bios I wouldnt think....
could my cpu be getting too cold? reads 1/1/10 on value/min/max? (HwMonitor)
