First off ill start with my build:
-Intel Core i7‑7700K
-ASUS ROG Maximus IX Hero LGA1151 DDR4 DP HDMI M.2 USB 3.1 ATX Motherboard
-Hydro Series H100i Extreme Performance CPU Cooler
-Hydro GFX GTX 1080 Ti Liquid Cooled Graphics Card
-VENGEANCE® RGB 32GB (4 x 8GB) DDR4 DRAM 3000MHz C15 Memory Kit
-AX860i Digital ATX Power Supply — 860 Watt 80 PLUS® PLATINUM Certified Fully-Modular PSU
So this was the first time that I have decided to overclock. I started from 4.5 GHz because my ASUS IX motherboard boosted it from 4.2 to 4.5 GHz by its self. Eventually i got to 4.8 GHz and then i ran into issues. I had it at 4.8 GHz @1.250 V and it black screened on me for the first time, so i went to the bios and put it at 1.255 V. After some time of gaming and doing one or two stress tests here and there it black screened on me again but this time when it black screened it wouldn't turn back on... i had to unplug my power supply and hold down my power button and re plug it back in for it to boot again.
After this experience i got kind of discouraged, my HW Monitor showed that it wasn't even staying at 1.255 V it was fluctuating up and down at 1.216 V. So i realized that even tho i was upping my voltage in the bios, it was not showing up in windows, (my friend when he overclocked told me he had his voltage at a solid number, where mine fluctuates lower than what i put it at)
how do i fix it so the voltage to my CPU stays at a solid number and doesn't fluctuate to lower voltages than what i set it to in the bios?
Also should i be worried that it black screened and i had to unplug my power supply for it to turn back on again? I head of black screens but i haven't heard of it not turning back on after trying to put it back on.
