Hello!
I recently purchased a CPU Cooler and decided to start overclocking my PC's components. I got stable frequencies for the CPU and iGPU but for the RAM i cant go past 2933Mhz (which is achieved with the XMP profile) even with everything else at stock speeds.I did also update the BIOS to P5.50 which includes the AGESA 1.0.0.6.
I followed this guide cause the one here on Tom's Hardware was a bit complicated for me.
https://www.overclockers.com/forums/showthread.php/785102-DDR4-RAM-overclocking-101-guide
I also did not go past 1.2Volts for the SoC and 1.35 Volts for the RAM DIMM Voltage cause i was a bit worried since my RAM indicates 1.35v on its cooler.
Any recommendations on what should i do or if it is even possible to go past 2933Mhz with this RAM/Motherboard combo?
Specs:
M/B: Asrock ab350m Pro4 / Bios P5.50
CPU: AMD 2200g
RAM: HyperX Predator 3000Mhz 2x8GB
GPU: iGPU Vega 8
Thanks in advance!
P.S.: Heres a table with supported RAM Frequencies from the Asrock's website.Does that mean i cant overclock more than 2933 Mhz?
https://imgur.com/a/KlUWt7S
Specs:
CPU: AMD 2200g
GPU: iGPU Vega 8
Thanks in advance!
