Overclocking RAM problem
Abhigyan_13
21
I bought a Ram 4gb ddr3 1333mhz and I already have 4gb ddr3 ram 1600mhz and so I changed dram frequency to 1600mhz...after rebooting the CPU components works fine but monitor displays nothing..what should I do???plz help!!!
Reset CMOS and then after you get a post go intro bios again. It should have set your frequency back to 1066 i guess. Set it to 1333 mhz.
What ram is the new 1333 mhz? You could make it to work by adjusting timings but i suggest that it doesn;t worth it. Go with 1333 mhz which should be stable
