overclocking sapphire r9 280x vapor x 3gb
lancerdude
42
hi guys,
jus wanna ask your advice on overclocking my vid card probably using the trixx ultiity. what are the safest values in overclocking it... tnx
Well, I have heard plenty on the Sapphire Vapor-X models.....They do have some floors as they have problems in heat dissipation and cooling the GPU, That said what is your currrent value?
my current gpu clock is at 1070
memory clock is at 1550
vddc is at 1200
current fan speed 24 %
and temp is 42'C
Hi guys I have 2 Sapphire r9 280x and my values is :
CPU 1028MHz
Memory- 1500MHz
and
work with
84 C temp
fan speed 98%
and my question... Is it normaly ?!
and how is better overclock
i have a sapphire 280x dual x, overclocked to 1090 MHz, no memory oc and stock volt, stock fan setting. ran a few thief benchmarks. looks stable. artifacts @ 1100 MHz.
hope it helps
