Hi Guys!
Need to know best bios setting for overclocking my i5 750 on Asus P7P55D!
I hv got CM Scout casing...2x2gb Corsair dominator ram (1600mhz)c8. Corsair tx650 watt psu and CM hyper212+ cooling solution.
i want to make it stable at 3.8 to 4.0ghz. plz tell me stable settings for these configurations.
till now the only stable setting i could get with my little knowledge is:
Using [X.M.P] Setting. 3.611Ghz
ratio: 18
blck: 200
vcore: 1.35
IMC: 1.3
Dram: 1.65
i know these are high but stability tests (prime95 and linX) only pass at these settings otherwise they give errors.p.s temp goes around 75c i m worried
what should i do? Any help would be highly appreciated.
waiting for expert replies
Regards.
UPDATE 1:
found one more stable setting after doing alot of testing with voltages.
Using [X.M.P] Setting: 3.611Ghz
ratio: 18
blck: 200
vcore: 1.275
IMC: 1.275
Dram: 1.65
PLL: auto
PCH: auto
LLC: Enabled
UPDATE 2:
found another stable setting after doing helluva of testing with voltages.
Using [X.M.P] Setting: 3.812Ghz
ratio: 19
blck: 200
vcore: 1.35
IMC: 1.3
Dram: 1.65
PLL: 1.9
PCH: auto
LLC: Enabled
No plz tell me how to get to 4.0ghz mark!
my voltage red zone starts above Vcore: 1.381v IMC: 1.30v and Dram: 1.681v
ratio: 18
blck: 200
vcore: 1.35
IMC: 1.3
Dram: 1.65
Regards.
UPDATE 1:
ratio: 18
blck: 200
vcore: 1.275
IMC: 1.275
Dram: 1.65
PLL: auto
PCH: auto
LLC: Enabled
UPDATE 2:
ratio: 19
blck: 200
vcore: 1.35
IMC: 1.3
Dram: 1.65
PLL: 1.9
PCH: auto
LLC: Enabled
