Overclocking with be quiet!'s Pure Rock
Eliasy
16
So this is my first time thinking about OC'ing and I'm very confundated since my CPU cooler is be quiet! pure rock, and I couldn't find reviews on it.
Has anyone tried to OC with this cooler? Please tell me how it went so I know if I could try OC my i5 4690K abit.
The be quiet! pure rock is mentioned to be about the same if not a bit better than the Cooler Master 212 Evo.
So depending on your CPU, you will be able to OC it, but there`s no way to say to what extent.
If your CPU is a good overclocker, and you need a low voltage for the overclock, you will be safe.
But if you need a high voltage for the overclock, this will result in gigh temperatures. So try to overclock until you reach the limit of 1.250V and I wouldn`t recommend to push any further.
Also, if your temps go over 80-85 degrees C while benchmarking your OC, that`s the highest you want to go.
So go ahead and OC. This cooler is an entry-medium level and it will get the job done if you`re not into extreme overclocking.
