KeelinTy :
philipew :
KeelinTy :
Ignore VID. You want to pay attention to Core Voltage. If it is just going a small amount past what is set, that is normal. I have mine set at 1.420 but the voltage goes up to 1.432 under load.
To counteract that, you need to set an offset voltage. So mine has a 12mv difference between what I set. So with offset, i would set it to -0.012v and that will keep the voltage a 1.42 instead of 1.432
In your picture, you have a 12mv increase. So the offset would be the same as it is for me.
That's really strange as voltage goes down under load - it is a protection mechanism - because the current goes up under load and "current (A) x voltage (V) = power (W)" - so it goes down to keep the resulting power down.
When the voltage drops under load, its called VDroop. The more current that goes through the 12v rail, the lower the voltage goes. I think the lowest it can go is like 11.5v before its out of tolerance. To counter act it, theres usually a setting in the bios called vdroop
Well, the (12 V supply) current is delivered via the PWM (Pulse-Width Modulation) phase control which should be as constant (high quality) as it can possibly be. Voltage variations should be limited to a few thousandths of one Volt, hence the need for a quality (preferably Gold) PSU, particularly as current and temperature increase.
My Gigabyte GA-Z170XP-SLI has three integrated drivers for the phase rails, as well as two more for the VCC and another two for the iGPU. A single Hybrid-Digital PWM provides the 4+3 phase output for the VCC (VCore) and VCCGT (iGPU voltage). The voltage set by the phases (accurate to the thousandth of a Volt) is between 1 and 2 Volt (INTEL set a "safe" limit at 1.520 V for 6600K VCore). The VCCSA and VCCIO are derived from a linear regulator considering their low power requirements. They too receive between 1 and 2 Volt (1.250 V on Auto). The current supplied by phases can go up to 20 A.
While a higher switching rate (the rate at which the current is supplied by the phases to the inductor via capacitors) is better for smooth current (less ripple), it also increases the temperature of the VRM (Voltage Regulator Module), the power delivery system of the CPU which converts the PSU’s extremely stable 12 V to whatever the CPU and GPU need – a high quality constant voltage with an extremely low fluctuation from its nominal value, best for stability overtime.
Due to VDroop, at 4.6 GHz my CPU VCore voltage, manually set at 1.355 V in the BIOS, varies typically between 1.332 V (under load) to 1.356 V (idle), or two 12 mV steps, which can cause stability problems ---> i.e. it FALLS from its set 1.355 V DOWN TO (not up to) 1.332 V UNDER LOAD and goes UP TO 1.356 AT IDLE (not under load).
With LLC (Load Line Calibration) I reduce VDroop and VCore drops to 1.344 V (under load) from 1.356 V (idle), or a single 12 mV step, which is very stable (Prime95 29.8 v2) --- i.e. it FALLS from its set 1.355 V DOWN TO (not up to) 1.344 V UNDER LOAD and goes UP TO 1.356 AT IDLE (not under load).
So, in contrast with what YOU wrote above, which is:
"I have mine set at 1.420 but the voltage goes up to 1.432 under load."
... in MY case:
"I have mine set at 1.355 but the voltage goes up to 1.356 AT IDLE" -----------> NOT UNDER LOAD.
Now, let's see... should I return my motherboard and write to the (then ignorant) Gigabyte engineers ;-) ?
