Overheat problems with my graphic card Nvidia gt 220
Jamall
48
Have some terible GPU overheats...my Desktop PC is dust free and have some brand new termal paste..but still got some badass Overheats...even when i play some low Games..so if someone could help me, would be nice..have a nice day
Well on HW monitor i have 11.000 rpm on it with like 80 degrees, never had probs with my GPU and CPU...2 months ago i had 40 degrees on Gpu and 30 degrees on Cpu, it was just to to fine...but now..damn...like in hell
Your cpu and gpu temps are slightly high. But it might be a hot day. When did you last clean out your case?
It doesn't say what fan is what. But no fans run at 8000rpm
You can download and run HWInfo - Sensors and post the results - 3 screenshots on TinyPic or similar. That will tell us what fan is running at what rpm and it will also tell us what temperatures are plus more.
Or as I said - Download and run Afterburner - to check your GPU.
Its dust free, but i think its the thermal paste...and u cant say it cant hit 8.000 because 5 moths ago i could hit 16.000 rpm then it shuts down <.<, and when i play games, it makes so loud noises, from the GPU Cooler..so i think my thermal paste is to old...can the thermal paste made me this problem ?
