As I mentioned in another thread. I was given a home-built computer. The owner died, so I don't know anything, about this overheating problem.
The case is a Thermaltake Xaser 3, with 7 fans installed. It has the temperature and fan speed controller installed.
When I received it. The owner removed the plastic side panel, and replaced it with a piece of window screen. I did not like this, because of the noise from the fans, and the screen was held in with duct tape.
So I decided to cover the large opening with a piece of aluminum. Also made a opening for one side fan, that would otherwise be covered, with the aluminum cover I made, to replace the screen.
Now, if I put the left side cover on, the computer overheats and shuts down, after an hour or so,
A few things I noticed. He installed the 32 bit version of Windows 7, but the motherboard can support the 64 bit version.
The interior wires are just a mess, just hanging everywhere, obviously blocking clear airflow.
The CPU appears to have a large round copper heat-sink, with a large fan inside it.
Not sure the builder knew much about computers/electronics, it doesn't appear so. May he rest in peace.
I am wondering if he even used heat-sink grease, between the CPU and heat-sink?
Otherwise, would the 32 bit version on Windows 7 be part of the problem?
Perhaps it can't handle several programs running at once?
I'm not using for gaming, like he used to...
I never had a computer overheat before, unless it was so full of dust and pet fur.
Any ideas of what I should look for?
I plan to disassemble the unit completely, blow out the dust, and move the wiring to the sides.
Still it should not be overheating, with 7 fans installed!
Any ideas or help will be appreciated.
Thank You!
Thank You!
