Hello everyone, I am posting this on behalf of my boyfriend. Here is what we're working with:
Motherboard: M5A99X EVO R2.0
CPU: AMD FX-6300 OC to 4.2 GHz, Bus Speed 211
RAM: 16 GB Corsair Vengeance 1600MHz DDR3
Storage: 50 GB SSD and 500GB HDD
GPU: SAPPHIRE NITRO Radeon R9 380, 4GB
CPU Cooler: CM Hyper 212 Evo
Case Fans:4x 120mm Fans, Pictured below (3 Thermaltake RIING 12 and 1 Enermax Cluster Advance)
Case: Corsair Carbide SPEC-01 Mid Tower Gaming Case
PSU: EVGA 850W
And the airflow diagram:
So here's what's going on. We were playing League of Legends last night and his GPU was superclocked (he said he increased core speed to 1100 MHz). He was streaming the gameplay at 60fps, 1920x1080 as well using XSplit Streamer.
This went on for about an hour and a half and then his GPU started failing. The game flickered in and out, the screen would go back and then recover. The entire time, the CPU temp was at 40C max but the GPU temp peaked at almost 90C, but was at 85C when the flickering started. When he noticed this starting to happen, he opened up the side of the case and stopped the stream. He also lowered the graphics settings on the game to low. When this did not help, he shut down his computer immediately.
Questions we (I) have:
1. This sounds like a classic case of an overheating GPU to me. Please confirm.
2. If any specs are wrong or extreme, please advise
3. I have attached a diagram of his case and airflow, and welcome any feedback on how to improve
4. How do we avoid this happening going forward, or fix it?
5. Recommendations on additional fans are welcome, please advise of placement.
Thank you for your time!
PSU: EVGA 850W
